I have an 01 Tahoe, my brake lights won't come on when I press the pedal, but the third brake light will. Also, when the headlights are on, they are on, but not when I press on the pedal. Any ideas on why and how do I fix it?
check the bulbs then check the sockets that they are in to make sure no moisture or correction is present . There is also present a stop lamp switch located just above the brake pedal could also be the problem. also make sure the fuse is good should be since the tail lights are running
