TAHOEdriver0468
Hello and how are you all tonight. I drove my Tahoe to work today with the inclement weather. After getting home I went outside to do the rear diff service.
Well, as I was removing the rear cover, I pushed you on the brake line. As I proceeded to do the oil change, I noticed the brake line was starting to look wet. Bolted the cover back on ( by the way this rear has 10 bolts, M8 x 20 mm ) filled with oil then I went to turn the truck around to do the front. brake pedal went right to the floor.
What I want to know, is Dorman offers a stainless steel kit, looks like around 90 buck on summit catalog, and 80 bucks on Amazon. Any of you guys use this kit before?
Thanks, TAHOEdriver0468
