Dashboard lights.....
tahoeman21
Wassup? the other night i was driving my tahoe and i quickly noticed that one side of my dash was dimmer than the other side... it was dimmer on the tach side... the rest of the dash was lit just fine.... any thought on what happening in there?:confused:
GMCYukalade
NC
Take the dash bezel off, - this is easy, it pulls right off - Start by putting the truck in 1st gear, (put e-brake on) and pulling the steering wheel all the way down - than pull bezel off - now, if you have switches for your rear hatch, and rear-weindshild wiper, you are gonna have to unplug these after the bezel is popped off, and just leaning down - also same thing for the 4wd switch if u have it - and also the headlight switch - now you don't have to unplug this one, you can pop the whole switch off of your dash, it is held on with 4 clips.. - and then take the bezel off - now, to get the guage cluster out, it is 4 small bolts, i think they are a 6mm or a 7mm you need a screw-driver w/ a 6mm or 7mm socket thing on there (or a ratchet w/ a good sized extension on it) - take the 4 screws out, and then pull the guage cluster out - notice it isn't attached to any cables or anything just comes right out - now on the back of the guage cluster you will see several plastic connector looking things, they actually have bulbs in them
tahoeman21
dashboard lights....
thanks for the info.... i will proceed sometime soon.... i will give you guys an update of how it went down...;)
