lone ranger
- Feb 5, 2008
I have a 1999 Tahoe 4x4 5.7. The other night the vehicle stopped running and it turned out to be the alternator. The night it broke down I towed it with a tow rope and hazard flashers on. The vehicle ignition was in the on position and the vehicle placed in neutral.
I removed the battery and charged it till it was fully charged. Bought a new alternator and installed it today, as it was in the 40s. The belt looked good so I didn't change it, but plan on doing it in the spring/summer and keeping this one as a spare.
After putting the car back together I started it and the hazard flashers came on and the dash lights continually blinked. The hazard flashers stayed on even if the switch on the column was pushed down.
Does something need to be reset?
Could the flasher switch have been damaged while the vehicle was in the on position, in neutral and being towed - turning the steering wheel?
Could the multi-switch be the problem for the dash lights flashing and the hazard flashers staying on?
Prior to the vehicle's alternator going bad there were no issues with the dash lights or the hazard flashers. There is no error code either. I have since disconnected the battery so it doesn't run down.
Thanks in advance.
Thanks in advance.
