You can start by checking the heater valve. These tend to be the cause of a lot of heater malfunctions by not opening and not allowing the coolant to flow through the heater core.
yup, it has the heater hoses going in and out of it. it should be right under thr overflow tank middle of the right side inner fenderwell. with the heat on all four hoses of the heater valve should be equally hot.
hose was dry rotted that came out of the valve the 8th inch one will replace tommorow and let you know. probably going to replace the whole valve its only 15$$
