I have a 1998 4 door tahoe LT. i actually love it even though it has been drainingg me for some time. I need to replace the weather striiping in the rear passenger window any ideas. also a couple of problems with my heater/ac it blows hot 80% of the time however it will start blowing cold for no reason and it will stay cold when stoped then heat up agaian with movement to the gas pedal. i see most believe that this may be the gasket however wouldn't I see a leak on my driveway and wouldn't it blow cold continuously also my heat ac only works and one setting if you try to change the vent settings by dial it will take at least 20minutes for it to kick over ie.. from defrost to floor . I would appreciate any input. w e have chnaged the fuel pump transmission oxygen sensors cv joints. too much in to give up. and if anyone knows a link to actually fix the gaskets lets me know. thanks for your time
