Hey guys.. I know some of you have electric fans... and some of you have manual overide switches to turn them on... but has anyone hooked up the AC turn on line successfully to the AC?
I have the PermaCool fans.. (they're awsome) and wanted to hook up the AC turn on wire (blue wire) from the Fan controller. Instructions say to hook it up to the pressure switch on the Drier. That's simple enough... so I tapped it into the green wire on the pressure switch (the switch has 2 wires... a blk/wht, and a green... this green one was recommended by another guy).
I believe my AC system works fine... I just had it recharged a couple days ago, and the new Sanden compressor works fine... but I had to manually turn on the Efans (attaching (+) power to the blue line) when the shop was charging the system. It blew nice and cold.
I tried hooking up the blue line to the drier switch last night, and the fans would not turn on when the AC was on... and the AC clutch was spinning fine too. This is not good. I tried unplugging the connector from the pressure switch, and then the fans turned on.... and the AC compressor stopped.
What gives... is my pressure switch bad? (my AC works ok).
Has anyone had any luck hooking up the EFans to activate w/ the AC compressor?
I plan to hook up a manual switch eventually, but would like it to turn on w/ the AC automatically anyway.
Any luck here?
Any luck here?
