leveling kit for 03 Z71 questions
hendedo
Hello all.
03 Z71, all stock with 105K miles. Looking for a leveling kit to pick it up just a bit. Will go with all-terrain type tire with stock wheels when done. What are the best ways to go up just a bit without a major redo of the front & rear suspension?
This is not a 'air ride' vehicle. All ideas and advice is apperciated. Thank you.
clkelley
Moderator
Galax, Virginia
A simple leveling kit will give you a minimum of 1.5 inches and up to 2 inches of lift in the front without messing with the back at all. You can also adjust the stock torsion bars a little without hurting things to save a little coin, but that is up to you. If you do that make sure to have it aligned afterward to ensure you don't ruin your tires.
