Light wont turn off
dion165
My light for overhead switches and light switches,4x4 switches will not turn off after ignition is off. Is there a relay controlling them? The cluster and door switches turn off just fine. I’m confused. I need help. Thanks
clkelley
Moderator
Galax, Virginia
What year make and model? Do you have an aftermarket stereo? In a lot of the newer trucks the lights, door chimes, etc are all run through the stereo harness and body control module. IF you have an aftermarket stereo that needed a harness adapter for installation, it is possible that either the BCM needs reflashed, OR the stereo adapter has gone bad causing it to lose the signal to turn those lights off.
