Can you tell me the location under the passenger front seat of the blue wire that needs to be cut in hookup lockpick rear camera feature for a '08 Tahoe?
Any details on how you got access to this wire would also be greatly appreciated.
A photo would be helpful also.
Thanks.
Figured it out. I took picture of connector in instructions and compared to connectors under passenger seat. I unplugged connector that appeared to match. Started vehicle and put in reverse and had no camera, so I was fairly certain I had the correct connector. To get to the connect I had to put the passenger seat all the way forward not back as silver box is located more in the middle of seat front and back and toward the center console.
Also, went for a short drive and couldn't get rear view camera to work while in drive. Notice that when I started the button push my window lock was in on position. Changed so I was starting with window lock off and then pushed four times and it worked.
Hopefully this will help someone else.
Thanks.
