Motor cutting out at high rpm
Tahoe52793
Hello, I have a 2007 tahoe with the flex fuel 5.3.
I installed a comp cams camshaft 54-451-11 with pushrods springs and a double roller timing chain recommended by the person I was speaking with at comp cams. I had it tuned by blackbear performance. My issue is during WOT mostly 2-3rd gear shift at 5-6k it will hit off of this invisible limiter. At this time the park assist will flash and my gauges will all reset. I am stumped as to what this problem can be as I did a data-log with justin from blackbear and he is seeing smooth acceleration the whole way. I have replaced my whole ignition system and alternator. I have good oil pressure and it doesnt seem to be like its starving for fuel. Any ideas?
Thanks,
Mike.
rockenthebowtie
Any time I want
Im not much of a high performance buff but I'm just taking a shot in the dark here youdon't think it may require a pcm performance software upgrade ?
longday
I would agree with rockenthebowtie. It may require a pcm software upgrade. Another thing to check is the fuel pump and fuel regulator.
longday
It can be bought from the dealer or with any performance shop.
rockenthebowtie
Any time I want
No not the dealer they only be able to provide the regular stock software updates but with you engine performance mods you did you want to go to a performance shop and see if they can help you
