98_2DR
- May 23, 2013
I am going thru fixing some problems with my truck and could use some guidance and advice...
1. My ac blower will blow fine some times and not other times. I will have it on high and it will be blowing the same on the second third and fourth setting then I'll hit a bump and boom it works like it should, I am not sure if it's the fan motor or the hvac controls.. any advice?
2. I'm needing to swap out my ignition switch with a new one and for the most part it seem pretty simple except for a very small white plastic connection on the box by where the key goes in, how do you remove this without breaking it.
3. My radiator has a hairline crack in the plastic tank on the drivers side.. I know a shop said for 80 bucks I can take my radiator to them and they will rebuild it. Or for 100 I can buy one from eBay or autozone and install it. I'm leaning towards just having mine rebuilt but not sure if I will run into any problems down the road. Anyone had this done with good or bad luck? ??
Thanks in advance for your help!!
:help:
:help:
