New member- Post your 99/2000 Z71 Tahoes
Mc_99z71
Hi everyone Im a new member, I own a 99 Tahoe Z71. Id like to see pics of all your 1999-2000 Z71s on here.
cshirey1980
99 5.7 liter vortec Chevrolet Tahoe. first ever four wheel drive and the four wheel drives giving me fits it's a matter of fact two weeks into owning said four wheel drive I remove the front drive shaft to make it to. Pray for me
Sent from my Pixel 2 XL using Tapatalk
cshirey1980
Just bought it last month. Turning into a bigger problem than is hoped for but still a great truck
cshirey1980
Just bought it a couple months ago
cshirey1980
Here's my 99 Z71. I got a phantom thump I'm trying to chase down but other than that she's perfect
Mc_99z71
The 4wd wont switch at all? Also what kind of thump are you getting? When taking off from a stop?
cshirey1980
No it's actually at shift points... Kinda. It's really hard to explain but it seems to happen when I let off the accelerator. And it's a very loud thing in the dive train. As for the 4x4, that was worked out with just getting a new interior switch
Mc_99z71
At least the 4x4 was a simple fix. My Tahoe has always made a driveline clunk but not when the trans is shifting gears. Its the slip yoke on the rear driveshaft at the transfer case which is common. It started making noise while driving and ended up being the u joint seized up but after fixing that I noticed the u joint at the rear end was loose where the straps hold the end caps onto the pinion. I havent fixed that yet but any play will make noise so check all that. Your trans and engine mounts, even leaf spring bushings. These trucks always seem to have driveline clunks. Let me know what happens and good luck
cshirey1980
Yeah I fought that fight to. Even used the raquetteball truck
