stilllearning6
- Apr 27, 2011
2003 Tahoe:
front heat AOK, coolant AOK.
Rear vents blow only cold.
Took apart the rear passenger side covering to reveal the HVAC system:
Hot coolant gets to heater core and return coolant line gets hot: heater core AOK.
Removed the Temperature Blend Door Actuator (HVAC transmission gear) box.
Inside gears look perfect, no cracked gears, nor cracked axles.
Inside transmission motor has continuity- AOK gear box box.
I feel that the TBDA gear box is AOK.
With the Actuator gear box removed, I could rotate the Blend Door axle to deflect hot air out of rear vents.
I conclude that the Blend Door is not being told to rotate.
With Actuator gear box unbolted and uncoupled from the Temperature Blend Door axle, I tested the Actuator gear box rotation via changing head unit temperature dial. The gear box Actuator never turned.
Conclude: either bad input signal to Actuator gear box or Actuator gear box is faulty. Since the Actuator gear box looked AOK and the gear box motor had continuity, I suspect that the Actuator gear box is not getting the correct signal.
I used multimeter to obtain the electrical signal from the HVAC Temperature Control Module ( possibly AC Delco PN 15832319 and /or PN 3734-07705535; Dorman PN 601-036) that sends signal to the TBDA gear box.
There are 5 wires from Temperature Control Module to the Actuator Gear box.
Results of multimeter with engine running at operating temperature and rear heater core is hot:
Brown wire: supply 12v-14v . Conclude AOK .
Yellow wire: ground . Yes, grounded to chassis , zero resistance. Conclude AOK.
Blue wire: Signal wire: 2.49 volts while engine running. Voltage holds at 2.49v even when I rotate the front dash area head unit temperature dial to change temperature from 65 degrees to 90 degrees. Conclude : ???
White wire jumped to Grey wire: 0.01 volts even when I rotate the front dash temperature dial from 65 degrees to 90 degrees. Conclude: ???
I suspect that the signal from the HVAC temperature Module is not giving the correct instructions to the gear box Actuator to change the position of the Blend Door. I believe that the white wire jumped to the Grey wire should have experienced a voltage change as I turned the temperature dial at the head unit.
That is my theory.
Can anyone add to this? Confirm or refute?
I plan to swap the $100 HVAC Control Module , as I believe it is the culprit.
Any feedback is appreciated.
That is my theory.
