mm66
I've got a friend with a 1999 Tahoe with a 5.7 equipped with the stock SFI system. About two weeks ago, the vehicle began to misfire and illuminated the CEL. It is throwing a p0300 Random Misfire code. We hooked it up to the computer with my scan tool and saw a lot of misfires. The misfire count seems to be increasing faster on the rear cylinders (5,7,6,8) and is not isolated to one bank. All cylinders were showing some misfires.
The idle is very erratic and the truck has a definite hesitation while driving. The exhaust smells very strongly of unburned fuel and in fact appears to spray fuel out of the tailpipe when accelerating after being stopped.
We went through the entire ignition system to see if that was the problem. Coil seems to be fine, as do all the plugs and wires. Wires, distributor cap, and plugs have recently been replaced (Approximately 1k miles ago). With the ignition seeming to be ok, we went ahead and moved on to fuel delivery.
We hooked a fuel pressure tester to the fuel line and immediately thought we had found the problem. Upon the key being turned on and engine still being off, the fuel pump will pressurize to 55-60 psi, but that pressure bleeds off completely within 15 seconds. When running, fuel pressure seems steady around 55 psi. I think that's within specs (53-60 psi right?), but everything I read states that the fuel pressure should hold constant after the key is turned off.
With this new data, we replaced the fuel pressure regulator. Unfortunately, this has not changed anything. Fuel pressure still bleeds off immediately after the key is turned off and the engine is still running rough. Worried that one or several of the injectors might be stuck, I pulled all of them out of their ports. Not a single one leaks a drop of fuel when the key is turned on.
At this point, I'm stumped. Everything I read points towards this being a fuel delivery problem, more specifically, the pressure regulator. Is the SFI system shot? Is my friend at a point where an MFI conversion is justified?
Thank you for your time.
