I have a 2003 Yukon SLT. It has power/memory seats in the front both with seat heaters. It started as an intermittent problem, one night I got back in my yuk from stopping at the grocery store and the seat didn't return to it's normal position for Driver 1 when I got in the truck. The seat heater didn't work in either seat either. I drove it home and let it just sit over night. Got in the next morning and all was good, the power seat moved, the heaters worked, excellent.
A few days ago I got in my truck again and the dirvers power seat wouldn't work, didn't recall it's memory position either. I checked the seat heaters and both of them didn't work either. The passenger power seat functions normally though.
What can I check to fix this problem. My truck just went out of warranty, prolly by a few hundred miles, this was an extended warranty so I doubt they'll be ok with a few hundred miles over.
One small thing I noticed about a month before this problem happens, on the drivers seat, to rais the seat up, I had to press down on the front portion of the power seat switch and to lower down I had to raise up on the front portion of the power seat switch. Weird!!! Also, I've checked some fuses and such, none seem to be blown. I've checked the power seat fuse under the dash by the steering column, but it's a large 30A, I will get a replacement to see if that fixes it. Any help would be GREATLY appreciated, I want my power seats back!!!!!
-Bryan
-Bryan
