Hello Everyone,
I'm new to the forum so nice to meet those of you out there. So lets get on to my detailed question. I have a 2000 Escalade with the 5.7 ltr. I have recently replaced the fuel pump about 3k miles ago. I have noticed afterwards about 3 weeks or so that the truck idles rough or misses about every couple of seconds. Not a bad idle though, just something I can tell through the seat of my pants. It runs fine through the rpm band and still gets up and goes. Just when I come to a stop and let it idle does it idle off a bit down to 650 and goes up occasionally to 750. The check engine light has accompanied the rough idle with a emissions leak, but when I put the new fuel pump in the tank I did it by the book and made darn sure the tank to pump gasket and retaining ring where on perfect. All hoses went back together and the new fuel pump wiring via the instructions went together easily and on the right way. I've done the pumps before so I believe it was correct to my knowledge. But with that idling issue it could be a number of things. Personally I think it's the EGR vavle recirculating incorrectly. But i took it off and clean it up and it's not siezed. So my dead end has lead me to thinking it's maybe a fuel pressure regulator or throttle positioning sensor. I have tools, but nothing really to check the fuel pressure and usually it's just cheaper to replace the TPS instead of fighting with it. Do you guys think I'm on the right path or did i miss something somewhere? Any help would be greatly appreciated!
-Blaine
-Blaine
