Service tire monitor system
ILoveMyHoe
I put new rims on (without pressure sensors) how do I disable the warning?
Thanks.
clkelley
Moderator
Galax, Virginia
You would need to find either someone with EFI Live V2 Sanner or Tech II scanner to disable the codes if I am not mistaken...
briando
Elkhart Lake, WI
you have to find a chevy computer expert. the tire sensors are the worst. the only time they ever go off on my car is when they themselves break, HATE IT
rfincher
Did anyone find out any more about the computer needed to disable the message? I have tried 2 dealers in Houston and both knew what I was talking about, but neither knew how to perform the fix.
Anything I can tell them to do?
clkelley
Moderator
Galax, Virginia
I did some more digging on this as far as I have found, there is not a way to disable the warning. The tire pressure monitor is controlled by the body control module and EFI Live does not make changes to that. Also, as far as I have found, there is no way that the dealership can do it either except to attempt to order a new BCM without the monitoring system programmed into it already. Especially on the GMT800 and GMT900 model trucks.
