Signatures?
Discussion in 'Site Suggestions and Feedback' started by bowtiefreak, Mar 10, 2012.
  1. bowtiefreak
    bowtiefreak Full Access Member
    77
    Apr 30, 2008
    Why can I not seem to find the way to have one anymore? Was this turned off in the great crash of 2009? ha-ha.
  2. clkelley
    clkelley Moderator
    1,111
    Jul 17, 2011
    Galax, Virginia
    Go to USERCP>Options>Thread Display Options and select to view images, signatures, etc. and see if that helps.
  3. HeadLightBulbs
    HeadLightBulbs Full Access Member
    179
    May 17, 2012
    Tahoe Forum Signature
    I think he is talking about the a signature similar to the one that you have in all of your threads?
    I tried to follow the instructions that you gave to add a signature to my posts but I couldnt figure out how to do change that feature.. Maybe im just doing it wrong? Maybe I dont have the capability to do that as of yet since im a new member?
  4. clkelley
    clkelley Moderator
    1,111
    Jul 17, 2011
    Galax, Virginia
    It may be turned off for regular registered members due to the spamming issues that were prevalent in the past on this site.
    My directions were flawed for just creating a signature I believe. For those that want to try it, follow the directions below.
    Go to: UserCP> Edit Signature and go from there. You should be able to find the Edit Signature link in the left hand menu of the usercp.
  5. HeadLightBulbs
    179
    May 17, 2012
    Signature
    I went and followed the directions you gave but I still dont see in that section.. The closest thing I see to it is under a filter of some sort to turn other members signatures off..
  6. clkelley
    clkelley Moderator
    1,111
    Jul 17, 2011
    Galax, Virginia
    Ok, then in that case, that option is turned off for regular registered users. This was done as a result of issues with spamming in the past.
  7. R_Zachs
    R_Zachs New Member
    21
    Dec 9, 2012
    Omak,WA
    wow, pretty regulated
