joshposh007
I've got a '05 4WD Tahoe LS with 88,000 kms. Recently when I started the truck, the LED display in the dash says "STABILITY SYS DISABLED" and the 4WD indicator light on the left hand side of the dash says the vehicle is in 4WD Low, after me shutting the vehicle down in 2WD previously. I've tried to switch back into 2WD, but the light just blinks for awhile, then stops. It does not go back to 2WD. It doesn't feel like the engine is in 4WD, but it's concerning none the less.
The engine also acts very sluggish when this "STABILITY SYS DISABLED" message is displayed.
I read in some forum to do the following to put it back to 2WD.
*** Make sure your vehicle is in Neutral when trying to return to 2WD from 4WD Low.
I did as instructed and it seemed to work. Does anybody know if this is a serious problem that I need to have a mechanic run some test on it? Doe s anybody know what this symptom is & point me at the right direction to have it fixed? I'd rather not take it to a dealer right away, does anyone have any ideas what could be wrong?
Any help would be greatly appreciated.
