scotto2323
Since the only answer I got to my question regarding label removal on visors was answered by, "have them rehopoulstered" (thanks for the help):rolleyes2: I went ahead and took matters into my own hands for those of you who wish to remove the unsightly warning labels from the visor or your 40-60 thousand dollar suvs.
*Disclaimer* Please follow the following instructions at your own risk. I am not responsible for any damages that may occur from this process. This method was used on my 2008 Tahoe. The first visor I did left some material bubbling in the cooler weather but tightened up in the heat. This first visor I did not do a final ironing to. Since I have done a final iron, it has been nice and tight. It does not have any discoloring or any other issues since I did this 3 weeks ago. Be careful if you have dirty visors, as the part under the label will be clean once label is removed.
Materials needed:
1. Iron
2. Piece of Wax Paper
3. Bottle of Goof Off
4. Clean Terry Cloth
5. Spray Bottle of Water
6. Hair Dryer
Instructions
1. Place wax paper over label on visor. Then use the iron on low heat setting moving it over the visor to heat the label up.
2. Peel the label off with your fingers or use a set of tweezers. The label will leave a slightly tacky residue.
3. Apply the Goof Off to the terry cloth and lightly rub it over the residue(do not scrub). Apply the Goof Off liberally over the area.
4. After you feel comfortable that the tacky residue is gone, use water on a clean part of the terry cloth and blot the Goof Off to try and rinse as much as you can off the visor.
5. You may now use a hair dryer to dry the visor to confirm that the residue is no longer there.
6. Finally after the visor is dry, take the wax paper and iron the visor one last time to assure all of the wrinkles are out of the material.
Enjoy your new visors:cool2:
Please advise me of any issues that you may run into, so I can alter this post to improve this mod.
I hope that more people will start doing writing ups. Simple ideas such as this will help out many.
Materials needed:
1. Iron
6. Hair Dryer
Instructions
