My 97 4wd Tahoe has stiff and unpredictable steering. It seems to wander around a lot. The power steering pump has been replaced with a new one as well as the hoses. The steering dampener as well as all ball joints, tie rod ends, idler arm and sway bar bushings are new. So I know the entire front end is new and tight. It also has a new alignment. The rag joint on the column is in great shape too. Even with all this, the pump still whines and fluid comes out the top on occasion. What is the electrical connection on the pump and what does it do? Does this effect the pressure? The steering gear has been tightened up slightly but the gear is the only thing I have not replaced. It does have a body lift and 33"x 12.5" tires. Everything else is new. Anybody else?
