I have done a lot of research on motor oil and additives, and from what I have read z max is a waste of money. It doesn't appear to do any damage, unlike Slick50 and other additives that contain PTFE resins(teflon). But there doesn't seem to be any reliable data that shows that it's worth the expense.
Spend your money on good oil and quality oil filters. Don't buy into the marketing hype that some of those companies throw at you. Modern motor oil is formulated with the needed additives for maximum protection. If you want to spend more each oil change, use a good synthetic oil. I use Amsoil, but there are several out there. And don't use cheap oil filters(stay away from Fram). If in doubt, go with oem filters.
There is a lot of information on the internet about motor oils and additives. Spend an hour researching it and you will know more about the subject than you ever wanted to know.![]()
I often throw some Lucas Oil in my engine (I substitute a QT for it) and I notice a difference in how it runs (a little smoother at idle and less noises when It's cold). Snake oil? Possibly, but it seems to make a difference.
