escaladeking
- Dec 13, 2011
HEY JUST JOINED THIS SITE..
p1345..valve timing off or cam sensor or crank sensor loose.
p0122..tps sensor open or shorted internally /check connector and wiring sensor.
p0300..cylinder misfire detected....faulty spark plugs,ignition wires,coil.
vacuum leak .
injector fault....
TRUCK GIVES HESITATION/STUMBLE..I SMELL GAS SOMETIMES TOO IF I AM FLOORING IT OR AT A HIGHER SPEED ON HIGHWAY..
SOME TIMES IT WON"T MISFIRE..(EX.)STEPPING ON GAS LIGHTLY.OR IDLE
JUST DID.
SPARK PLUGS AND FUEL FILTER,CHECKED ALL SPARK PLUG WIRES 1 BY 1 WHEN RUNNING AND NO CHANGE IN IDLE
vacuum leak .
injector fault....
JUST DID.
