Towing/Remote Battery
mary900
Adams, TN
A test light shows that I do not have 12-volts at the 7-pin connector plug at the hitch. Has anyone run the wire from the fuse under the hood to the hitch? If so, what was involved?
mary900
Adams, TN
--2008. I think on the newer models the center pin that used to be the 12-volt is now for the b/u lights and/or the beeping sound when backing up.
woldd90
Alpharetta, GA
The center pin on mine is used for reverse lights... You could always check the connections inside the 7 pin connection.
mary900
Adams, TN
The attached .jpg shows steps taken to resolve my issue.
Armycop
Detroit, MI
yep, that's the one!
Got here too late! That would be the correct answer, Mary. With the Tow Package option, the 40a fuse is already in. All I had to do was find and hook up my power and brake contoller lines to the posts. And wire my controller, of course. Glad you found the solution!
