A test light shows that I do not have 12-volts at the 7-pin connector plug at the hitch. Has anyone run the wire from the fuse under the hood to the hitch? If so, what was involved?
Got here too late! That would be the correct answer, Mary. With the Tow Package option, the 40a fuse is already in. All I had to do was find and hook up my power and brake contoller lines to the posts. And wire my controller, of course. Glad you found the solution!
