'09 Tahoe - Please help
cbutler25
Tennessee
Please take a look at the video I just made of my 2009 Tahoe. It was running just fine and then it started doing what you see in the video. It was also barely running as if it was going to shut off. Seemed like some type of electrical deal but I have no clue. I eventually just pulled over, shut it off, and let it sit for about 10 minutes. The issue miraculously went away but the engine light remains on. I appreciate any advise/recommendations.
Chad
http://youtu.be/rx3K9IDZ7bM
bladenbullet
SW Florida
what was the voltmeter doing while this was happening?....hhave you had a chance to scan for diagnostic trouble codes yet?...
shutting down and restarting is like rebooting a locked pc...sometimes it makes concerns go away for the time being....but something caused the problem...itll be interesting to see what you find...
cbutler25
Tennessee
It jumped up above normal operating levels as well. The engine light eventually went off as well. Can it still be scanned for diagnostic trouble codes?
bladenbullet
SW Florida
it can always be scanned for dtc's....depending on the failure one may be stored in history...there can be many reasons why a vehicle can react this way....the dtc(s) will at least give a starting point and direction....
cbutler25
Tennessee
Thanks, I appreciate the quick response. I'm going to go to my local Chevy dealership and see if I can get a DTC. I will let you know if anything shows up.
MO Viet Vet
Soon to be Missouri
They will likely charge you for the scan. Lots of parts stores do it for free. get the "exact" code(s) #'s and report back here. Don't buy anything yet. Especially since it running ok for now.
cbutler25
Tennessee
Ok, the local dealer said they can't see me until next Friday. Such a waste of time. I'll see if one of the parts stores can help out.
Javsamjor
I could be completely wrong here. But I just posted my 2007 tahoe dying and having very strange electrical problems. I did have my alternator checked in December, it was over charging therefore causing some issues. Then I just got my truck back yesterday and after getting GM involved, they found my negative
Ground cable to the battery was bad. not sure if they just said that to shut me up, but we r grasping for straws at this point. Point is was I see on ur utube is very similair to mine. Just a thought. Good luck to u....
cbutler25
Tennessee
Just wanted to update you all on my issue. I finally made it to a local shop here. They put it on their machine and this is the code that came up: P2101.
They told me that the throttle body could be bad and may need to be replaced which was about $300-$400. Instead of going directly with replacing that, they recommended started with an easier solution first. They recommended cleaning the throttle body to see if I would have any more issues first. Then if I still get the same issues then replace it. So we will see what happens and I'll post another update later.
Scan Test - $42.95 Code:P2101
Labor to clean throttle body - $35.00
http://engine-codes.com/p2101_chevrolet.html
(Javsamjor) I inquired about a possible bad negative ground cable to the battery as well. They checked it out as well and it was good.
bladenbullet
SW Florida
i had a similar issue on my envoy that was caused by a bad throttle body...surging and eventually a quit and no restart....
the charges they quoted are reasonable compared to many shops....
cbutler25
Tennessee
I kinda figured eventually I'm going to have to replace it. If it acts up again that is what I'll do.
Just curious what year is your Envoy? How many miles when it started acting up?
bladenbullet
SW Florida
the envoy was a 2002...approximately 110k when it acted up....135k when we sold it and still ran and towed like a champ....
cbutler25
Tennessee
Ok thanks, I'm just trying to see if there is a common trend when this particular issue happens or not. I currently have about 113k.
rockenthebowtie
Any time I want
Theres a special coverage policy for that.. take this to your dealership. . 11273B: Special Coverage Adjustment - Throttle Position Sensor Replacement - (Dec 16, 2013)
Subject:*11273B — Special Coverage Adjustment – Throttle Position Sensor Replacement
Models:*2008-2011 Cadillac Escalade, Escalade ESV, Escalade EXT2008-2009 Chevrolet TrailBlazer2008-2011 Chevrolet Avalanche, Express, Silverado, Suburban, Tahoe2009-2011 Chevrolet Colorado2008-2009 GMC Envoy2008-2011 GMC Savana, Sierra, Yukon, Yukon XL2009-2011 GMC Canyon2008-2009 HUMMER H22008-2010 HUMMER H32009-2010 HUMMER H3T2008-2009 Saab 9-7xEquipped with V8 Engine (LFA, LY2, L20, LMG, LC9, LH6, LMF, LH8, LH9, L76, LS2, LY5, LY6, L92, L96, LZ1, L94, L9H)
This bulletin has been revised to include 2008-2009 Saab 9-7x export vehicles. Please discard all copies of bulletin 11273A.
ConditionOn some 2008-2009 Saab 9-7x; 2008-2009 Chevrolet TrailBlazer; GMC Envoy; HUMMER H2; 2008-2011 Cadillac Escalade, Escalade ESV, Escalade EXT; Chevrolet Avalanche, Express, Silverado, Suburban, Tahoe; GMC Savana, Sierra, Yukon, Yukon XL; 2008-2010 HUMMER H3; 2009-2011 Chevrolet Colorado; GMC Canyon; and 2009-2010 HUMMER H3T vehicles, equipped with a V8 engine, the throttle position sensor may cause the engine to run rough and cause the malfunction indicator lamp and/or an Engine Reduced Power message to illuminate. If this occurs, it could result in reduced engine power.Special Coverage AdjustmentThis special coverage covers the condition described above for a period of 10 years or 120,000 miles (193,000 km), whichever occurs first, from the date the vehicle was originally placed in service, regardless of ownership.
Dealers are to replace the throttle position sensor and reprogram the Engine Control Module. The repairs will be made at no charge to the customer.
Owners of 2008-2009 Saab 9-7x vehicles delivered in the U.S. or Canada will receive a separate notification and be addressed by Saab Authorized Service Centers. This bulletin applies to those 2008-2009 Saab 9-7x vehicles delivered outside of the U.S. and Canada that are subject to this special coverage.
For 2008-2010 model year vehicles: For vehicles covered by Vehicle Service Contracts, all eligible claims with repair orders on or after September 21, 2012, are covered by this special coverage and must be submitted using the labor operation codes provided with this bulletin. Claims with repair orders prior to September 21, 2012, must be submitted to the Service Contract provider.
For 2011 model year vehicles: For vehicles covered by Vehicle Service Contracts, all eligible claims with repair orders on or after June 28, 2013, are covered by this special coverage and must be submitted using the labor operation codes provided with this bulletin. Claims with repair orders prior to June 28, 2013, must be submitted to the Service Contract provider.
Vehicles InvolvedAll involved vehicles are identified by Vehicle Identification Number on the Applicable Warranties section in GM Global Warranty Management system. Dealership service personnel should always check this site to confirm vehicle involvement prior to beginning any required inspections and/or repairs. It is important to routinely use this tool to verify eligibility because not all similar vehicles may be involved regardless of description or option content.
cbutler25
Tennessee
(rockenbowtie) I apppreciate this. I just got back from my local dealership and they are going to honor the special coverage adjustment that you so kindly shared. Where did you find this by the way?
My issue with my local dealership is they have poor service in my opinion. So I get there and stand around for 15 minutes before anybody even acknowledges that I am there for something. This happened the last time I was there as well for a routine oil change. So when one of the guys finally asked me if I needed anything I explained my situation to him. I also had inquired about why this was not brought to my attention the last time I was in here. He said if it was not a problem they would not bring it up. How about give me a courtesy to look out for this issue and if it occurs bring it in and we will take care of it. And I also clarified with him what exactly they were going to do so there was not any confusion. He responded with yes if there is a problem. Are you serious. So I'm probably going to call the person in charge of the service department and inform him of the way things are running at his business.
James Corlew Chevrolet
722 College St.
Clarksville, TN 37040
bladenbullet
SW Florida
special policy adjustments are public knowledge...theres no secret....owners are generally mailed a copy in case they have incurred similar expense and to keep in the event they experience a similar failure....
dealers are welcome to share technical service policy bulletins with customers and are required to apply them when a vehicle that qualifies for and requires the repair is present....
rockenthebowtie
Any time I want
@bladenbullet.. Thats only on some not all.. some require the actual failure to occur.. and again my source is accessible to all service information bulletins not just public ones.. : )
bladenbullet
SW Florida
they are all public information....and all require failures to be applied except in certain customer satisfaction situations....only recalls do not require failure...I managed general motors service departments for 17 years and am intimately familiar with the legalities and application of special policies...they are required by law to disclose all policy adjustments to vehicle owners...
the "silent recall" is a myth and there is no non-disclosed service policy information except goodwill policy that is determined on an individual basis for customer satisfaction reasons...
