ABS and Brake light
The short answer is that most Tahoe’s (99-03?) will develop this issue over time and it’s the EBCM computer gone bad. This only pertains if the ABS+BRAKE light turn on together. You have 2 options: (1) buy an OH’d computer so the when you remove yours you can install the replacement, or (2) remove yours, secure/protect the area for dirt, water etc… and send yours for repair. Although option 1 is more expensive, I prefer it because you do it once and you’re done. Here’s the history behind my ABS+BRAKE light problem. My Tahoe developed the issue and over time it would happen more and more often. At first I would simply turn off the truck and restart and the lights would stay off. After a while nothing seemed to work and the lights would simply come on around 15 minutes after operation (about the same time the brake system does its checks).
After reading many forums and performing all sorts of tests like:
- Cleaning wheel sensors
- Changing wheel sensors
- Flushing brake system
- Cleaning electrical terminals @ the EBCM
- Cleaning/ changing main fuse.
I finally gave up and broke down and changed the unit. I am happy to report that after 3 months and about 2K miles (NC vacation road trip) all is well and no more lights.
The unit removal is a bit of a tricky if you don’t want to disconnect the brake lines, but if you strip the left rear torx bolt it becomes a bitch(not impossible) but a bitch quickly.
1) Remove all the electrical plugs, even the ones in the far back.
2) Remove the entire assembly from the mount.
3) Remove the mount.
4) With the unit freely hanging from the lines you should be able to twist it -GENTLY- just enough to get the rear left torx out.
The rear left torx is tricky because the EBCM frame gets in the way and doesn’t allow the torx bit to sit square on the screw head. So use a thin bit and mirrors to better you odds.
GOOD LUCK!
