2002 tahoe will not start
curley03
I checked the fuses and relays all seem to be ok. Engine cranks but will not start. I tried start fluid but that did not help. Any ideas???
curley03
I had a local shop change the fuel pump. He thought it was a hose coming loose or breaking. I checked the pump and could not find anything wrong. It was just a remove and replace job. I don't think the mechanic knows what is really wrong. I'll see what happens when the tank gets low again. If it is really fixed or not.
ZG05HOE
brown summit nc
i had a similar issue with my 05 ,like everyone says check fuel and spark , any check engine lights ? mine ended up being a crankshaft position sensor failing
