2003 tahoe rear a/c blowes hot front blows cold
UglyDog
:mad3: I have a 2003 Tahoe the rear air blows warm with front blowing very cold. The rear air gets hotter if you turn selector to hot. the lines going to rear rear evap. do not change temps while front lines are hot and cold like normal. anyone had this problem before. I replace dryer compressor and orifice to front evap. core. thanks for any help. :au:
72hotrod
These trucks usually work OK in the rear when the front starts getting weak from low charge. May be a defective or plugged up TXV. If that is the case, there may be more problems down the road if the problem is related to compressor trash plugging the valve. You need to see what's in the orifice tube.
