So, it's hot now and big surprise my cold AC from last year has disappeared when I need it most.
When I push the AC button the little light won't come on, initially the light would come on for a few seconds then cut off, pushing the button on/off a few times would make the light come on for another few seconds. Now the light doesn't come on at all. At no point did I hear the compressor clutch click on. Wondering if the AC light is dependent on another part of the AC system and that's why the light doesn't come on, or if the switch is just burned out. Any ideas?
Haven't checked the r134a pressure, don't have a gauge. With two wires going to the compressor switch I'm not sure which one to check for power. Does a low/empty system keep the compressor from running?
Edit:
1995 GMC Yukon, 5.7L, single AC, Auto
Any help with suggestions/diagnostics would be appreciated. Thanks.
Edit:
