Any way to tighten slack out of seat track?
clean97LT
My driver's seat has a little play in the bottom cushion mount, either it's the track or where the seat itself mounts to the track. It's not bad, but I'd like to not have any play in it at all. Any ideas on solving the problem without replacing the track would be very appreciated! Thanks!
qlc1964
st.louis mo.
i have the same problem but my seat frame that bolts to the motor track it cracked
and making a clicking sound when braking or hitting bumps.
i had to screw a flat piece of metal over the cracked spot then drill holes in it to mount
it back on the track. i fixed that noise but it still rocks a little.
every thing is welded on that track
clean97LT
Thanks for the advice, I'll check mine tonight to see if it's cracked.
