Yeah.....its done through the DIC. I did it on my Tahoe but can't really explain how but I do know it hassomething to do with those control beside the AC vents to the left of the steering wheel with the check mark and stuff!
hmmm maybe because its an 07? my dad has a nbs 07 silverado and his are to the left of the steering wheel
also what about just doing the turn signals and fog lights for the approach? is that possible?
APPROACH LIGHTING
This feature allows you to select whether or not to
have the exterior lights turn on briefly during
low light periods after unlocking the vehicle using
the Remote Keyless Entry (RKE) transmitter.
Press the customization button until APPROACH
LIGHTING appears on the DIC display. Press
the set/reset button once to access the settings for
this feature. Then press the customization
button to scroll through the following settings:
OFF: The exterior lights will not turn on when you
unlock the vehicle with the RKE transmitter.
ON (default): If it is dark enough outside, the
exterior lights will turn on briefly when you unlock
The lights will remain on for 20 seconds or until
the lock button on the RKE transmitter is pressed,
or the vehicle is no longer off. See Remote
Keyless Entry System Operation on page 115 for
more information
does anyone know if it's possible to disable just the headlights on the approach lighting setting?
I don't know of a way to do this, but if you figure it out let me know! I hate to have my HIDs turn on and off like that, though I would still like use of the under mirror lights.
