Limited00
I decided to forget about waiting on ppl to install my wires and stuff and do it myself! Not bad for a first-timer! Let me know what you think
Here's the kick paneling(?), all the wires are tucked away nicely!
Here is my amp (4000D Watt Power Acoustik). What you don't see is my 4ga. wire running under the kick paneling, then under the carpet, and then under the metal bracing for the rear seats. Makes it a very neat install. The other wires (RCA and Remote) are tucked under the carpet as well, kinda difficult to do.
I decided to use an Interstate 18 Wheeler battery in the back. You'll notice that the 4ga. (from left to right) is coming from under the rear seat bracing and to the battery, then back down between the seats near the ground wire.
Here you can see where the battery ground is. I used the bolt along the seat bracing as a decent ground, and from there it goes to the amp.
You can now see where the ground and the other "hot" wire goes into the amp. Also, I have a Memphis Car Audio Line Driver hooked up as well. Works quite well!
I don't use fuses, but circuit breakers. More efficient to me! Let me know what you think!
Limited
Limited
