clunking from rear after eibach install
REALSPEED
ohio
I installed the eibach lowering springs a couple of months ago on my wifes 08 yukon, and now there is a clunking from the rear suspension when going over bumps, anybody else have the same issue? I think that it is the rear shock dust boots but I have'nt checked this yet, any ideas????????
73shark
KC, MO area
Are you sure it's not hitting the bump stops due to the shorter springs?
REALSPEED
ohio
no, I did trim the bump stops as per the eibach installation sheet, I just dont know what it could be...
tspain
Memphis, TN
Double check that the springs aren't rubbing against the frame rails.
I've come across many doing this from the factory, with factory springs.
You'll have to spin the springs around until you get some extra clearance from the frame rails.
