2004 Tahoe 4.8 automatic.......
Im getting these codes and the engine is running like its on 7 cylinders, so I know they are not false codes.
P0300-Engine Misfire Detected (SES)
P0307-Cylinder 7 Misfire Detected
I changed the plug, plug wire and coil pack on that cylinder and still not fixed. I did not do a compression test on that cylinder yet.
What else could it be? Crankshaft position sensor (you have to remove the starter to get to it?)?
