jgm74
Does anyone know if the automatic headlights can be bypassed so they only come on when I want them to.
And if so, how it's done?
Thanks,
Jim
Thanks,
Jim
When necessary, you may turn off the Automatic Headlamp System and Daytime Running Lamps feature by following these steps. When the system is turned off, the headlights will not automatically come on when it becomes dark outside.
1. Turn the ignition to RUN.
2. Press the DOME OVERRIDE button four times within six seconds. After the fourth press of the button, a chime will sound informing you the system is off. The system will revert back when the ignition is turned off and on again.
3. To return to the automatic mode, push the DOME OVERRIDE button four times within six seconds, or turn the ignition off and on again.
For a permanent fix, you will have to wire in a resistor into the dash sensor.
