Hello guys and gals, im stuck on my repair. I need help identifying a wiring harness/cluster the connects the ignition to the ignition power on a 2010 chevy tahoe. Ill upload pics when i get back to the shop. The truck was stripped of some things and ive fixed everything except for this exposed wire cluster. I strongly suspect that the exposed end of the cluster use to have a connector on the end that plugged into the Junction i/p block under the driver side.
But the problem is even if i do replace the connector how would i know which wire goes into which section of the connector fixing my starting issues.
