HIDs low/fog & LED ex/interior installed (PICS) !
mkim1120
just got finished installing all the exterior and interior leds.
i ordered the 4410 festoon but they were a bit long.
i suggest a 4210 would have been perfect.
HIDS are 6000K and LEDs are all hyper white on the exterior and cool white on the interior
going this weekend to get the K2 LED Taillights installed as well as a 15.4'' Savv overhead screen and since my screen is only navigation i am having a 1/2 din Savv dvd player installed into the center console
scotto2323
TR, NJ
Looks great, these pics are going to motivate me to order my **** already. Where did you buy everything from?
tbully
Can I be lazy and ask for part numbers for each?
My Denail should be here within 6-8 weeks and would like to do a similar mod.
(HIDs for both Headlights and Fogs as well as LED around...)
Thanks for the pictures!
mkim1120
low-h13
fog-9005, stereo efx knew that the bulb needed to be modified to fit w/o burning the housing
led-exterior:194, interior: used 4410 but 4210 would be a better fit
also have plans to change out the city/parking lights (amber bulb above the low beams) in the headlights to give it a cleaner look. that one takes a 4157, but can be substituted for 3157
will have those pictures up after i receive the bulbs and install
hope this helps
scotto2323
TR, NJ
What about reverse lights? Sylvania says that 7441 is required, can 7440 or 7443 be used?
mkim1120- what was the exact style 194 wedge did you buy?
mkim1120
reverse lights i didnt plan on changing
i was just going to put the k2 led taillights on
but after looking at one of the members post
i might go w/ HID reverse lights
for the 194 i purchased off superbrightleds.com
WLED-WHP Pure White High Power
hope this helps
jazejeff
riverside ca.
7440 is the reverse light
dont forget to call me if you want those k2 lights
951-343-0806 ask for jeff
scotto2323
TR, NJ
Installed same model dome bulbs as mkim1120 and I am happy with the results. The 39mm or 42mm would have been a better fit but there are 3 less leds in those, which is why I went with the 44mm. Cool White does seem to have a bit too much blue tint to it but they look good.
Same license plate bulbs, they are great.
I also installed 7440-WHP3 LED bulb in reverse lights.
They look great matching the license plate ligts for approach lighting. But beware they do not offer near the light as factory bulbs when backing up.
mkim1120
plan on doing a HID reverse light upgrade
i recently got my "parking/city" lights done will take pics tonight
Playa70
autolumination.com has alot of LED bulbs there as well. That's where I ordered mine from, just make sure you look at the size of the bulb (as in length and width, not just the bulb number) because some of these lights are wider and longer than a normal one.
scotto2323
TR, NJ
My friend orders alot from them, but prices were better at Super Bright LEDs.
"plan on doing a HID reverse light upgrade" What kit are you buying for them? Size?
"i recently got my "parking/city" lights done will take pics tonight" What did you do to them?
mkim1120
http://www.tahoeforum.com/showthread.php?t=9105
HID reverse will be done similar to laredotahoe..he used a h11 bulb
