limited slip axle?
denali814
i drive a 2002 yukon denali 6.0L awd, how would i go about knowing if it comes with or without limited slip axle?
You can take the VIN to a local dealer and have them print a build sheet or have someone online do it. You can also take the codes from the label inside the glove box and look up what you have for everything...
denali814
thank you, although i cant take full credit for it, i actually found it on here..lol
denali814
seems i have the limited slip axle, code for it if anyone cares is G80
vwbeaner
I was going to tell you to put one wheel in gravel and one wheel on the black top and hammer on it. But you found the code anyway.
