falconmanconvert
- Feb 17, 2015
my 09 tahoe heat guage only climbs to about 175. the dealer replaced thermostat but that didnt help. he also said it had a air bubble in it. where do I go from here?
Ok got it, i that case remove the surge tank hose from the radiator and visually inspect the radiator tank nipple that feeds the surge tank. If the radiator is missing the surge tank restriction orifice there will be an increased amount of coolant flow to the surge tank. Excessive coolant flow may induce low ect temperature and may even set a dtc P0128 ECT BELOW THERMOSTAT REGULATING TEMPERATURE
If the radiator surge tank restriction is missing, the radiator needs to be replaced with the proper replacement radiator
