Radio wont shut off
TxGal
I have a 2007 Tahoe, recently when I turn the Tahoe off and get out the radio is not shutting of. By any chance did I change a setting to do this or is something broken. The tahoe is new to me and with all this new stuff on cars these days I am not sure what is going on.
Thanks for the advice :waytogo:
Tex99Tahoe
Fredericksburg, Texas
Hey, TxGal, I'm clueless about your later model, but I recall something about 'retained power' after the ignition switch is turned off, something about allowing passengers to operate windows and the radio while you step out to try on the latest cowgirl boots.
Whatcha could try is to turn off the radio BEFORE turning off the ignition switch. If that works, you've solved it. If not, sounds like the radio (power switch) needs to be checked...
TxGal
Retained power
Thanks so much for the reply !!
What I have been doing is just turning the radio off when I turn the Tahoe off but I thought I remembered when I opened the door when the car is turned off the radio went off. But who knows maybe I am getting old and don't remember correctly. When I looked through the owners manual I saw the part about retained power, but I did not see a setting to adjust it. If anyone knows please let me know. !!
:happy160:
kutza
Yorktown VA
we had similar issue after a warranty drivers door lock replacement. The replacement part was faulty, and and internal switch powers down once open. That became bad.
You may need to chk the drivers door lock?
