think i can help here, as i had mine off last week end changing the speakers
(sorry i dont have pics of this, but here goes)
1)remove one 7mm hex bolt behind the door pull handle(this screw is about 2 1/4" long)
2)remove the same screw, same size, behind manual door lock knob
hint: i used a very small precision flat blade screwdriver (in alabama we know this as a "minus"):smilielol: use this to gently pry out the manual door lock tab and housing-you will see this screw as soon as you remove this door lock housing( the indicator is the part that has the bright orange on it)
3) at this point i like to remove the interior-colored "triangle " piece at the top right, by the window that gives access to the outside mirror---just work it loose by gently pulling--it has 2 or 3 metal clips on the back side of it--just pull evenly and gently all around it.
4) put your hands on the bottom of the door panel, and give a firm push---straight up--i also placed one hand on the door pull and one at the base of the door panel and pulled straight up; the door panel will now be loose--you will see it just "hangs" on the door frame with white colored clips--
****remember**** the door panel will have wiring coming from controls for windows, doorlocks, heated seats at the drivers door module---also the courtesy light at the bottom left of the door panel will also need to be considered---the bulb and socket will come out by pinching lightly on the connector base and pulling towards the front of the vehicle; the drivers door module has connector plugs that will pull out in the same manner--
****ALSO**** as i was removing mine, or learning how to, rather, i heard a slight cracking noise; no damage was done to mine, but i learned that these panels are made out of fiberglass, which doesnt flex much in my experience, so be gentle, and it will come right off--
good luck with it--
marcus
