julio
with ike getting in the way of things i finally got around to installing the 4" springs to get rid of the rake look. originally i installed a springtech 2/3 spindles and spring kit and was very pleased with the ride but it still had some rake and it was more than i wanted, 1.5" higher in the back to be exact. i did some searching and found out belltech makes a 4" spring and ordered them. the spring (sorry forgot to take pic) is the same height as the 3" spring but is thinner gauge and has less spring tension so i wouldnt recommend it if your tahoe is going to be used for towing heavy. the springs also called for belltech shocks but i kept the oem's with the shock extenders and in 2 days of driving i have not bottomed out once. compared to the 3" the ride is the same but i have heard some slight rubbing on hard turns from body roll. overall im very happy with the look and handling.
here is the before pic
after
and one more (glass fogs with hid upgrade coming soon)
after
