Miss Old Motors
- Dec 5, 2008
Got a few questions for yall. First off, i seem to have aslight misfire every once in a while. It always idles great, but at a cruising speed or acceleration now and then I can feel a little surge, because of this I am assuming that it is a fuel issue, right? It does have a brand new fuel pump, not even 2000 miles on it, could it possible be a fuel pressure regulator or an injector?
Also, recently I did put intake gaskets on it, and while I had the intake off it looked to me like one of the injectors was at one point spraying sloppy because there was a nice amount of carbon built up around one injector and on the bottom of the intake. The smart thing to do would have been to replace said injector, but I had other opinions from a mechanic that said not to worry about it and it probably had fixed itself.
few more....
I have the barn door style rear doors, and the one with the door handle on it (the one you open first) leaks REALLY bad in rain or carwashes... but it is not a weather strip type problem because there is about a 1/2 gap at the top of the door, it still shuts and opens fine however. The door itself is not damaged neither are any areas around it. any ideas of what I can do about this?
Door locks are seised up, i have tried spraying penetrating oil into them and letting them soak but it hasnt helped at all. Do i have to replace the entire assembly or is there something i can do to repair it?
Steering is really lose, I have been told it is an evo sensor or something on the column? I tried searching around about it but im a lazy ass.. What is involved in replacing this?
few more....
