2001 Tahoe Replacement Sub Question
PhiDeltaTheta_MN
Greenfield, MN
Hey everybody, I was wondering if replacing the factory sub in the back, near the rear door, with a $50-$100 brand-name one would increase bass levels and overall sound quality. I haven't pried the panel off yet to take a look at the stock one though, so maybe a stock sub in decent shape won't sound much different than a brand-name new one?
Thoughts? Thanks
phi3nd
Sub
You are in luck. I just replaced my stock subwoofer last night and it was really easy. I ordered this kicker 10cvt8 shallow subwoofer for $75. You have to snap off the plastic trim around the speaker to get it to fit into the factory sub box but that's not hard or a big deal. You can check out the sub and read reviews from the link below. If you have any questions let me know.
http://www.amazon.com/Kicker-10cvt8...dp_top_cm_cr_acr_txt?ie=UTF8&showViewpoints=1
phi3nd
It sounds a lot better than the stock sub but is not going to be that much more bass unless you hook an amp up to it. It's definitely worth upgrading though.
phi3nd
Definitely! I looked into this for a week before I pulled the trigger. Like I said, I just did this last night and it was superrrrrrr easy. One thing I'd recommend is removing the cheap OEM matting in the sub enclosure and buying some poly fil from a fabric store and fill up the box.
