2003 Tahoe Brake Problems
MRH1958
Been working the brakes on my 2003 Tahoe 4WD, had a rear caliper go bad and lost some fluid, I replaced the rotor and caliper and pads, when I tried bleeding the rear brake caliper I could get very little fluid to come out and brakes are really soft and go nearly to the floor and are not moving the caliper pistons at all , I tried to bleed the other side rear caliper and got the same result as the first one, fluid barelyy coming out, what do I do next here ? bleed master cylinder ? , brakes were fine before the caliper went bad, also the "service brakes" light is on thanks in advance.
MRH1958
Figured it out.......major air in lines, used vaccum pump and finaly got all the air out.....good as ever now...hopefully this will help someone out having similar problems
