2015 Tahoe/Yukon third row seat removal
genestoy
Phoenix, AZ
Has anyone removed their 2015 third row seats? I need more cargo space and would like to remove all of the compartments and seats. If somebody has done this how big are the pieces once they are out (thinking of storage size)? Anybody have any pictures of the floor with them removed?
Thanks for any help
Gene
73Vetteman
Livonia, Michigan
3rd Row Seat Removed
I immediately removed my 3rd row seat. It takes up space in my basement now. I cut a piece of 1/2" plywood to fit the cargo area. It covers the holes in the carpet where the seat legs bolted to the floor. I used a Weather Tech full size rubber mat to cover the area.
It provides substantially more cargo space and I don't have to strain myself lifting items so high anymore.
Rather angry I had to pay a lot for a leather bench I will never use. They should have left it as an option.
Dante9121
I got a dealer demo with power 3rd row. Didn't want the option but got a great deal. I want to remove the 3 row as well for the same reason as above. Does anyone know if the power has a plug or is it direct wired. Also need to know if electronics would get screwed by removing them. Thanks
genestoy
Phoenix, AZ
Removed my 3rd row seats today from my 2015 Yukon SLE
First remove the plastic covers under the front of the seat by pulling them upwards to release (just snapped in)
genestoy
Phoenix, AZ
Next remove the front bolts with a 15mm socket
Next remove the rear bolts with a 15mm socket
genestoy
Phoenix, AZ
Next separate the two seats, the two front bolts are 15mm and are horizontal, the single rear bolt is vertical and is 13mm
genestoy
Phoenix, AZ
Remove the 60% seat first by lifting the front to clear the peg, then remove the 40% side
Picture shows parts removed to remove the seats
Dante9121
Thanks for the post. I'm hoping the power 3d row is just a lug or harness I can hide after removing.
genestoy
Phoenix, AZ
Mine of course did not have power seats but here is what you will have, just a connector
jsturge
2015 3rd seat
Why didn't they make this seat removable like the previous models it's uncomfortable to sit on for one thing and with it in limits cargo capacit I'm not getting one for that reason I hope the 2016 or 2017s have that option!
bjwpj001
2016 3rd row seat
I checked on the 2016 and there is no option to get one without the 3rd row seat.
reddog
genestoy, I've followed your directions and I'm almost done, but I can't figure out how to open the electrical connector. Any advice? Many thanks.
genestoy
Phoenix, AZ
Mine did not have the electrical connector so can't help you there. It will come apart so there has to be a release somewhere on the connector and most of them have a small tab that you press to release.
reddog
Figured it out...
Just needed a small blade screwdriver to release the connector. This was a much easier job than I'd imagined. The seats are all bagged up, waiting for the next owner, whenever that may be!!
Thanks again genestoy!!
genestoy
Phoenix, AZ
Yep, mine also are all wrapped in plastic in the attic storage above my garage and will not see the light of day until I trade it off someday!
athansjim
JY
Have you taken out the power third row seats yet? Thinking of buying but will not if they do not come out.
cmarucco
Curious why you put in plywood? Doesn't your weathertech cover the holes in the carpet?
Also, for the others who have removed the third row already, when you put the regular rear seats down now, are they much higher than the back? Meaning, with the back seats down, I assume it's not flat now, right?
I think I have to remove these third row seats too. I'm so tired of **** rolling out of the back when I open the liftgate. Bad design GM.
Thanks.
T-Man
Does anyone know if this is the same assembly for a 2015 Suburban? I would assume so, but you know how that goes.
