A/C parts replacement question
mattress
My A/C hasn't worked since I bought my Tahoe about 2 years ago. The system has a leak in the discharge and suction line at the high/low quick connectors. The threads the quick connectors screw onto are so worn that no good seal can be made between the line and the connectors. I bought a new discharge/suction line, new compressor since mine made a funny noise anyway, accumulator and orifice tube. I want to replace these parts myself to save on labor costs, then just take it down and have it evacuated and charged, but don't know what seals and/or o-rings I will need to replace in addition to the parts. Anyone know off hand what seals/o-rings I'll need, and is the dealer the best source to get them, or is there a better/cheaper place to get them?
Mike97
Colfax, WA
They are just o-rings. Nothing special about them. You can get them at any hardware or auto parts store.
I would just replace every o-ring you see when you tear it down. I'm not sure if there are any seals for the parts you are replacing. Sorry.
We need an online service manual for this forum. Then you would know for sure.
tspain
Memphis, TN
You'll need the seals for the line set to compressor. Seal where the line goes to the acc., high side line to condensor. If the other seals aren't leaking, then don't mess with them. Sometimes aluminum corrodes, and you can damage threads and fitting trying to remove them.
mattress
Anyone happen to have an online service manual or microfiche? This is annoying, I'm used to working on motorcycles and every bike I have I can get online and find microfiche for, with part numbers and prices.
