Brandon00hoe
Hang on I'll see if I can find the info.
Took 3 days for mine. Just got in from the garage. Waiting for it to get dark to adjust. Got them working, by cutting the small female and male connectors from the ballast to the bulb and soldering them together.
FYI, make sure you check the small female/male connectors that go from the ballast to the bulb. Check to see that the wire are in the plastic clips and tight. That was one of my problems. Not sure what would of happened if that wire fell out and made contact with metal somewhere.
Someone on an earlier post in this thread said something about buring them in? Are you supposed to let them run for so long?
Are you guys disabling the drl's????
Where did you mount them? I used self taping screw along with a zip tie threw a factory hole in the fan shroud where the upper and lower halves come toghter.
Now I have to get fogs. Not from VVME though![]()
